2025-08-24 10:13 PM - last edited on 2025-09-09 4:54 AM by Andrew Neil
In my case, the STHS34PF80 sensor module is powered using I2C communication with the ESP32 module, and I have tested its functionality only up to 2 feet; beyond that, it fails to detect any presence. However, the datasheet indicates that it should cover 4 meters without a lens in an 80-degree field of view. What might be the reasons for this discrepancy?
2025-08-29 6:16 AM
Hi @Ashwin_versa ,
For the configuration of the sensor and of the presence detection algorithm, we suggest to follow the procedure described in the AN5867.
2025-08-29 6:16 AM
Hi @Ashwin_versa ,
