2020-05-11 6:07 AM
2020-05-12 5:54 AM
Yes, you can test this using our STWIN eval kit. IIS3DWB would be the recommended component to capture the vibration data for the first analysis, since it has the widest signal frequencies coverage and on top it has excellent attenuation for the out of band signals . After the first analysis of the data you may decide if you need a vibration sensor or another accelerometer with potentially lower measurement bandwidth.
