2020-12-26 2:47 PM
I have one axis on the LSM6DSO that gives a lot of false positives due to some vibrations on the board. I know there is a way to set the step count and duration thresholds, but is there a way to adjust the sensitivity or motion threshold of just one axis for a constant vibration source?
2021-01-04 3:39 AM
Hi @CQuin.1 ,
please check if this thread on similar topic can be of any help for you.
You can start from checking your code with the lsm6dso_pedometer.c file on Github that configures the LSM6DSO to enable the pedometer embedded function.
-Eleon
