2021-08-10 5:01 AM
2021-08-11 7:41 AM
Hi @MVida.1 ,
I think you are referring to the cross axis between the various IMU axis (for example, x vs y, or y vs z for the accelerometer, and pitch vs yaw or yaw vs roll for the gyroscope).
These data are not available in the datasheet, so I can share you only typical values on a small subset of samples.
Consider also that in the gyro case the quadrature is compensated at production tester level, so you'll have to take into account of just a residual quadrature.
Keeping a "distributional" margin, the cross axis is below 2%.
If my reply answered your question, please click on Select as Best at the bottom of this post. This will help other users with the same issue to find the answer faster.
-Eleon
2021-08-10 5:02 AM
Dear Sir or Madam,
Is there a way to know the orthogonal error of the LSM6DSM iNEMO inertial module? I am looking for high precision measurements and would like to take into account the error on the orthogonality between the axis.
2021-08-11 7:41 AM
Hi @MVida.1 ,
-Eleon
2021-08-12 12:36 AM
I guess we can calculate an estimated value of the orthogonality between the axis with the cross axis.
Thank you for your time.
