2018-06-20 9:58 PM
Hi, I'm in trouble about LSM330TR gyroscope power_down mode.
I'm measuring the angular velocity every 100ms and when it isn't measuring, i'd like to implement power_down mode.
I wrote such a program but t
he gyro data is just a random variant number.
When I use only normal mode, it works correctly.
How long does it take to start up from power_down mode to normal mode in gyroscope sampling sequence?
Please help me.
https://community.st.com/tags♯/?tags=inemo-inertial%20modules
‌‌‌#lsm330tr #gyroscope #inemo-inertial-modules2018-06-21 2:06 AM
The turn-on time from power down to normal mode is 150ms so you can you this approach if you want to measure the value each 100ms.
2018-06-21 8:25 PM
Thank you Miroslav, I made sure it works correctly!
I was looking for the information about power-down mode in this datasheet, but I couldn't.
https://www.mouser.jp/datasheet/2/389/lsm330-955021.pdf
I wonder if you tell me where can I see the description.
2018-06-22 4:47 AM
The LSM330 is obsolete sensor. Is no more present on st.com, you want be able to to find more information there.
I got the information about the turn-on time from sensor specialists.
