2014-11-18 10:53 AM
Some day ago I've started work with LIS3DH accelerometer. Everything works fine -Reading accelerations, highpass filter, low power mode and INT1 interrupt line.At start INT1 was configured as high when active (CtrlReg6 = 0x00 - default value) I want to inverse polarity of INT1 so I send 0x02 to CtrlReg6. Until that, every register which I set before has value = 0x00, also CtrlReg6. Registers are written in orderly:CtrlReg1,2,3,4,5,6I read errata, datasheet and application note and I didn't find any information which could help in that problem.Has anyone seen similar behavior and have some tips how to fix that issue?Thanks a lot.Radekuntil I send data do CTRLREG6.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
