2014-12-15 7:09 AM
hi all
I want to use long periodic reading 3 axises. I configurate the LIS3DH using by reference source code ODR = 100Hz Normal_power mode turn on the x,y and z enable. then now I read 3 items for 1 sec period. It happended Overrun...I read 16th or 14th it occured the reset... It means all parameter value reset to zero. So I want to use BDU(Block Data Update) or any possible method? what should I do?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
