2014-01-14 2:04 AM
I would like to know : how did you calculate the L3GD20 sensitivity (LSB/dps) in the example?#define L3G_Sensitivity_250dps (float)114.285f /*!< gyroscope sensitivity with 250 dps full scale [LSB/dps] */#define L3G_Sensitivity_500dps (float)57.1429f /*!< gyroscope sensitivity with 500 dps full scale [LSB/dps] */#define L3G_Sensitivity_2000dps (float)14.285f /*!< gyroscope sensitivity with 2000 dps full scale [LSB/dps] */What does the ''f'' mean ? Because I tried to calculate these values and I found : 262.144 LSB/dps for a 250 dps full scale, 131.072 LSB/dps for a 500 dps full scale and 32.768 LSB/dps for a 2000 dps full scale. The 16 bit output data is expressed as two's complement so : Sensitivity (LSB/dps) = 2^16 (bit) / FullScale(dps).Thank you in advance for your time.Kind regards,RomainWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
