If the electrode is embedded in an insulator, isn't the sensing process dielectric polarization rather than electrostatic induction?
Shion
Associate II
The following text is quoted from 「Application Note "Qvar sensing" (AN5755) p2.
「 A signal is derived from the electronic circuit due to the fluctuations in the electric field resulting from the passage of the charged particles. If the electrode is embedded in an insulator or there is no direct contact between the electrode and the particles, the sensing process is achieved through electrostatic induction. 」
1 ACCEPTED SOLUTION
Accepted Solutions
Federica Bossi
Hi @Shion ,
When the electrode is embedded in an insulator, the sensing process at the electrode is primarily electrostatic induction, but it is strongly influenced by dielectric polarization of the surrounding insulator.
2 REPLIES 2
Federica Bossi
Hi @Shion ,
Hi @Federica Bossi
Thank you for your comment. That being said, it was so. Is there a document that explains in detail the physical principles of this sensing? If so, I would appreciate it if you could let me know.
