2019-11-19 10:37 AM
2019-11-19 10:52 AM
3.3 volts is perfectly fine. Well within the range of the device. Not an issue. Please insure you don't exceed the max range. That would be bad.
The interrupt is active low by default, but there is an API to change that.
