2025-11-13 5:16 AM
It's mentioned in the datasheet that the sensor will convert the FIFO from streaming (reading data all the time) into FIFO (holding the data until it's read)
If i am getting it right, then my question is
When exactly will the sensor read ?
Will it read 32 samples after the interrupt and then stops ?
Or will it just turn into FIFO immediately after the interrupt ? and discard the samples after the interrupt holding the data before the interrupt ?
Thanks
2025-11-13 7:45 AM
Hi @abduuu ,
Which product are you referring to?
2025-11-13 7:54 AM
Sorry, forgot to mention it, LIS2DH12
