2015-02-02 11:49 PM
Hi everyone,
I was wondering if there is an updated version for the UM1755 which (partially) describes the commands available for the BlueNRG chipset. I can't find decoding scheme for the VS HCI events for example.Thank you.2016-01-13 10:43 AM
Could you please help me with this frame ?
Thank you.
04 ff 03 01 00 01
2016-01-15 3:40 AM
Dear Customer,
here below the description:0x04- Event type
0xff - HCI_VENDOR;
0x3-Parameter Total Length;
0x01,0x00 - (0x0001 little endian) - Evt_Blue_Initialized
01 - Reason_Code ->Firmware started properly
This event occurs when the BlueNRG-MS firmware is started normally, it gives a Evt_Blue_Initialized event to
the user to indicate the system has started (with Reason Code 0x01).Regards,
GMCould you please help me with this frame ?
Thank you.
04 ff 03 01 00 01
