2022-11-15 6:22 PM
Hello friend,
I programmed a blueNRG-1 MCU using ST Link V2. But I need to use BlueNRG-1 ST -Link Utility's application to erase MCU and need to pull up a pin (for SWD program). Then unplug the ST link V2 and plug it in. Release the pull-up pin and use the application of BlueNRG-X Flasher Utility 4.0.0 to burn the firmware and BD address at 0x10005fff4. This is very inconvenient. Does anyone have a convenient burn-in program for MP to use.
Thank you in advance.
Ted Wu
2023-03-03 7:52 AM
Use a Keil with a free licence, it's very easy to flash and debug with that.
Hope help you.
