SPWF04 Station Disassociation
Jobin Joseph
Associate II
Posted on February 03, 2018 at 06:29
I am using SPWF04 module for embedded web server application. I can access web pages on the web server from the PC/laptop, but when i access from android phone wifi module reports station disassociation.
8 REPLIES 8
Elio Cometti
Senior II
Posted on February 05, 2018 at 14:18
Can you please detail the scenario when the module reports station disassociation? console log, what is the station doing, ecc.
I suppose your SPWF04 is configured as MiniAP, isn't it?
Posted on February 05, 2018 at 16:39
The SPWF04 configured as MiniAP. When i connect the wifi on the phone, it showing as connecting...... obtaining ip address..... and this process is continuing. On the console showing station is associated and after few seconds showing station is disassociated and this is process is continuing.
at
AT-S.OK
AT+S.FCFG
AT-S.OK
AT+S.RESET
+WIND:2:Reset
+WIND:1:Poweron:171117-0328fe3-SPWF04S
+WIND:13:Copyright (c) 2012-2017 STMicroelectronics, Inc. All rights Reserved:SPWF04SA
+WIND:65:Factory Reset:1
+WIND:0:Console active
+WIND:3:Watchdog Running:20
+WIND:32:WiFi Hardware Started
+WIND:21:WiFi Scanning
+WIND:35:WiFi Scan Complete:00
AT+S.WIFI=0
AT-S.OK
+WIND:49:WPA Terminated:0
+WIND:38:WiFi Powered Down
at+s.ssidtxt=Release Tool
AT-S.OK
AT+S.SCFG=wifi_priv_mode,1
AT-S.OK
AT+S.SCFG=wifi_mode,3
AT-S.OK
AT+S.WCFG
AT-S.OK
AT+S.RESET
+WIND:2:Reset
AT+S.WIFI=1
AT-S.OK
+WIND:26:Started AP:Release Tool
+WIND:24:WiFi Up:0:192.168.0.50
+WIND:24:WiFi Up::fe80:0:0:0:280:e1ff:febd:ff11
+WIND:28:Station Associated:24:DA:9B:17:21:8C:0
+WIND:72:Station Disassociated:24:DA:9B:17:21:8C:8
AT+S.GCFG
AT-S.List
AT-S.Var:nv_manuf=ST
AT-S.Var:nv_model=SPWF04SA
AT-S.Var:nv_serial=3817Z24857
AT-S.Var:nv_wifi_macaddr=00:80:E1:BD:FF:11
AT-S.Var:standby_time=10
AT-S.Var:standby_enabled=0
AT-S.Var:sleep_enabled=0
AT-S.Var:etf_mode=0
AT-S.Var:blink_led=1
AT-S.Var:ext_volume=3
AT-S.Var:ramdisk_memsize=16
AT-S.Var:aes128_key=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:user_desc=anonymous
AT-S.Var:python_script=3:/uPython_test.py
AT-S.Var:python_memsize=32
AT-S.Var:console_enabled=1
AT-S.Var:console_speed=115200
AT-S.Var:console_hwfc=0
AT-S.Var:console_echo=1
AT-S.Var:console_errs=2
AT-S.Var:console_winds=2
AT-S.Var:console_verbose=1
AT-S.Var:console_repeater=0x21
AT-S.Var:console_delimiter=0x2C
AT-S.Var:console_wind_off_low=0x00000000
AT-S.Var:console_wind_off_medium=0x00000000
AT-S.Var:console_wind_off_high=0x00000000
AT-S.Var:wifi_tx_msdu_lifetime=0
AT-S.Var:wifi_rx_msdu_lifetime=0
AT-S.Var:wifi_operational_mode=0x00000011
AT-S.Var:wifi_beacon_wakeup=1
AT-S.Var:wifi_beacon_interval=100
AT-S.Var:wifi_listen_interval=0
AT-S.Var:wifi_rts_threshold=3000
AT-S.Var:wifi_ssid=52:65:6C:65:61:73:65:20:54:6F:6F:6C:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:wifi_ssid_len=12
AT-S.Var:wifi_txfail_thresh=5
AT-S.Var:wifi_dtim_period=1
AT-S.Var:wifi_add_tim_ie=0
AT-S.Var:wifi_region=1
AT-S.Var:wifi_ht_mode=1
AT-S.Var:wifi_channelnum=6
AT-S.Var:wifi_opr_rate_mask=0x003FFFCF
AT-S.Var:wifi_bas_rate_mask=0x0000000F
AT-S.Var:wifi_mode=3
AT-S.Var:wifi_auth_type=0
AT-S.Var:wifi_atim_window=0
AT-S.Var:wifi_powersave=0
AT-S.Var:wifi_tx_power=18
AT-S.Var:wifi_rssi_thresh=0
AT-S.Var:wifi_rssi_hyst=0
AT-S.Var:wifi_ap_idle_timeout=120
AT-S.Var:wifi_beacon_loss_thresh=10
AT-S.Var:wifi_priv_mode=1
AT-S.Var:wifi_wep_keys[0]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:wifi_wep_keys[1]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:wifi_wep_keys[2]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:wifi_wep_keys[3]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:wifi_wep_key_lens=00:00:00:00
AT-S.Var:wifi_wep_default_key=0
AT-S.Var:wifi_wpa_psk_raw=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
AT-S.Var:wifi_wpa_psk_text=
AT-S.Var:wifi_eap_identity=identity
AT-S.Var:
mailto:wifi_eap_anon_identity=anonymous@identity.org
AT-S.Var:wifi_eap_passwd=password
AT-S.Var:wifi_eap_type=0
AT-S.Var:wifi_eap_skip_datechecks=0
AT-S.Var:wifi_wps_walk_time=120
AT-S.Var:wifi_wps_pin=1234567
AT-S.Var:ip_sock_memsize=1
AT-S.Var:ip_sock_threshold=0
AT-S.Var:ip_dhcp_lease_time=120
AT-S.Var:ip_macfilter=00:00:00:00:00:00
AT-S.Var:ip_num_clients=5
AT-S.Var:ip_allow_port_scans=1
AT-S.Var:ip_use_v6=1
AT-S.Var:ip_use_dhcpd=1
AT-S.Var:ip_use_httpd=1
AT-S.Var:ip_use_tftpd=1
AT-S.Var:ip_use_dhcpc=2
AT-S.Var:ip_hostname=iwm-BD-FF-11
AT-S.Var:ip_apdomainname=captiveportal.net
AT-S.Var:ip_apredirect=firstset.html
AT-S.Var:ip_ipaddr=192.168.0.50
AT-S.Var:ip_netmask=255.255.255.0
AT-S.Var:ip_gw=192.168.0.1
AT-S.Var:ip_dns1=208.67.222.222
AT-S.Var:ip_dns2=208.67.220.220
AT-S.Var:ip_local=0:0:0:0:0:0:0:0
AT-S.Var:ip_dns1v6=0:0:0:0:0:0:0:0
AT-S.Var:ip_dns2v6=0:0:0:0:0:0:0:0
AT-S.Var:ip_dhcp_timeout=20
AT-S.Var:ip_ntp_server1=ptbtime1.ptb.de
AT-S.Var:ip_ntp_server2=ntp0.ipv6.fau.de
AT-S.Var:ip_ntp_refresh=3600
AT-S.Var:ip_ntp_startup=1
AT-S.Var:ip_mdns_domain_name=SPWF04S-Default
AT-S.Var:ip_mdns_device_name_ttl=120
AT-S.Var:ip_mdns_services_name=SPWF04S-WebSrv SPWF04S-TFTPSrv
AT-S.Var:ip_mdns_services_prot=_http._tcp _tftp._udp
AT-S.Var:ip_mdns_services_keys=dev1 dev2
AT-S.Var:ip_mdns_services_vals=number1 number2
AT-S.Var:ip_mdns_services_port=80 69
AT-S.Var:ip_mdns_services_ttl=120 60
AT-S.Var:ip_mdns_startup=01:01
AT-S.OK
AT+S.STS
AT-S.List
AT-S.Var:build=171117-0328fe3-SPWF04S
AT-S.Var:fw_version=1.1.0
AT-S.Var:boot_version=1.0
AT-S.Var:var_version=2
AT-S.Var:free_heap=38216
AT-S.Var:min_heap=35360
AT-S.Var:system_time=946689264
AT-S.Var:system_uptime=177
AT-S.Var:system_sleeptime=0
AT-S.Var:reset_reason=2
AT-S.Var:startup=0
AT-S.Var:random_number=3136117926
AT-S.Var:gpio_enable=0x0000
AT-S.Var:app_fs=1
AT-S.Var:ram_fs=1
AT-S.Var:user_fs=1
AT-S.Var:extvol_fs=0
AT-S.Var:nv_power_cycles=28
AT-S.Var:nv_wdog_resets=1
AT-S.Var:nv_reset_cycles=61
AT-S.Var:wifi_state=10
AT-S.Var:wifi_own_macaddr=00:80:E1:BD:FF:11
AT-S.Var:wifi_bssid=00:80:E1:BD:FF:11
AT-S.Var:wifi_aid=0
AT-S.Var:wifi_sup_rate_mask=0x003FFFCF
AT-S.Var:wifi_chan_activity=0x00001FFF
AT-S.Var:wifi_max_tx_power=18
AT-S.Var:wifi_gf_mode=0
AT-S.Var:wifi_reg_country=
AT-S.Var:wifi_dtim_period=0
AT-S.Var:wifi_num_assoc=1
AT-S.Var:ip_from_AutoIP=0
AT-S.Var:ip_linklocal=fe80:0:0:0:280:e1ff:febd:ff11
AT-S.OK
Posted on February 05, 2018 at 19:35
From log I understand you are setting WEP encryption without a password.
I'm not sure it is a valid configuration.
Actually, I cannot get an IP until I set a valid password (40/104 bits) in the SPWF04.
Ex.:
pwd=54321
AT+S.SCFG=wifi_wep_keys[0],3534333231
AT+S.SCFG=wifi_wep_key_lens,05
Ex:
pwd=1234567890123
AT+S.SCFG=wifi_wep_keys[0],31323334353637383930313233
AT+S.SCFG=wifi_wep_key_lens,0D
Posted on February 05, 2018 at 23:01
See the attached console log, i implemented password and still same cannot connect with android phone.
But i can connect with laptop without any issue. Actually i was using version FW1.0.0, this version dont have any connection issue with both PC and phone.
________________
Attachments :
teraterm1.log.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hy4S&d=%2Fa%2F0X0000000b3a%2FYyCLyAOlm6_KjxnhAXpqwj0Bhj3.dmZg5sKKPdExUZ4&asPdf=false
Elio Cometti
Senior II
Posted on February 06, 2018 at 10:16
Thanks for the log.
Is the phone disassociating during the access to the web server, or is the phone failing to get an IP?
Posted on February 06, 2018 at 14:59
I am not accessing web server because its not even connecting to the wifi properly. I think phone is  failing to get an IP. When i connect  the wifi on the phone it show
 connecting...... obtaining ip address..... and this process is continues.
Posted on February 06, 2018 at 15:36
Can you please capture the DHCP Offer or ACK packet sent by the SPWF04 to the phone and send to me?
Also please try setting a static IP on the phone for the 'Release Tool' network.
Posted on February 06, 2018 at 16:08
How i can
capture the DHCP Offer or ACK packet sent by the SPWF04 to the phone?
