2016-06-17 5:07 AM
Dear Community,
I am trying to use PRINT macro available in BLE1 examples pack (SensorDemo). Is there a way to turn serial communication with the device, as turning DEBUG definition on doesn't allow any COM output? Thank you, Pawe? #bluenrg-serial-com2016-06-29 1:38 AM
I have found out that uncommenting #define DEBUG 1 in SensorDemo was causing the system to lock. I guess that is ST's coding style that if a definition is commented it shall remain commented while when it is set zero than can be changed to 1. Regards,
PawelWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
