ST60A2G0 availability
Hi all,I would like to use the ST60A2G0 chipset for a design. According to the ST website, the chip has been available for quite a while. However, I couldn't find any distributor who actually sells the chip. I found a connectivity module on amazon (l...
fmm by Associate
  • 1146 Views
ST7580 Powerline Communications stack
I'm using STM32F401 with ST7580 with Nucleo-plm01a1 in Powerline Communications.Are present PHY and DATA layers, but not upper stack layers.Someone knows if there is a stack's higher levels for this hardware?Thanks in advance.
marco2 by Associate III
  • 1626 Views
Multiple CAN frames
Hi,I am working on a CAN Bus project with TCAN1051 and STM32G0. In this project i have to send approx. 175 bytes of data though CAN. It will take around 22 frames to send this data. And i can't figure out how to send all the frames. If i send all of ...
Resolved! How do I select different output voltages from the STUSB4500 without using a microcontroller?
I want to use a STUSB4500LBJR for USB-C power delivery. On the datasheet stands that connecting the I2C lines is optional and in another datasheed of the STUSB4500 stands that I don't have to use a microcontroller. But I cannot find information about...
