How to switch from using LPUART to using USART1 at the AT_SLAVE project in the b-l072z-lrwan1 software package?
I am working on a project using the I-Cube-LRWAN software package, precisely the AT_SLAVE project form the b-l072z-lrwan1. I want to upload the AT_SLAVE project on a L0 MCU interfacing the cmwx1zzabz-091 LoRa module. Then I have an other MCU (L4 MCU)...
Ksouk.1 by Associate
  • 1165 Views
Please supply below component data, my will to verify design circuit and to meet IEC 61508 required, The FIT data for MTTF or MTBF report. Component list to below description: TS391ILT
Please supply below component data, my will to verify design circuit and to meet IEC 61508 required,The FIT data for MTTF or MTBF report.Component list to below description:TS391ILT
雙林.1 by Associate
  • 792 Views
stsw-bnrg-mesh package printf means transferring the data through uart. How can we print message in IAR terminal i/o using semi hosting?
Hi Sir/MadamWhile opening lightning demo application with IAR, in the target option->general option->library low level interface implementation->stdout\stderr is disabled. Why it is disabled?How to enable the stdout\stderr option(via semihosting)? ...
Anitha by Associate III
  • 550 Views
BlueNRG-M2 no SPI signals
Hello,I am currently working with a BlueNRG-M2 module and STM32L433CC. I am unfortunately struggling right at the beginning.....I tried the example codes generated with CubeMX but nothing worked.So I tried to write my own code in a test project with ...
attemptx by Associate II
  • 716 Views
