Using the STM32L476RG-Nucleo dev board with the Wi-Fi extension (X-NUCLEO-IDW01M1 ) Been following the Step-by-Step Guide: SPWF0xS firmware upgrade over UART (attached PDF) found in the STM32CubeExpansion_WIFI1_V3.1.1
I need SPWF FW version v1.1.0 to flash onto the board (pg.8 Select the binary file to program the Flash) have been unable to locate SPWF01S-160129c5bf5ce-RELEASE-main.bin or any updated version.
NDami.1 by Associate
  • 1295 Views
how to set custom frequency for st7580 ?
Hi I am using NUCLEO-L053R8 with XNUCLEO- PLM01A1 board connected which is having ST7580. i am able to run the basic example given but now i wanted to change the Maximum central frequency which is in configurable as per the document *https://www.st.c...
ytriv.1 by Associate
  • 1020 Views
