2023-06-26 7:42 PM
HI, i am studying how to controll vl6180 with a custom board which MCU is STM32L452CCU6. At the beginning , i tried to avoid implementing the api by changing register directly using i2c, however,0x018 is set to 0x2 or 0x0 both did not generate the raw value in 0x064.
Therefore, i think there are more config i need to be made before the sensor start reading and an API is required . During searching in the internet, i only found STSW-IMG003 for VL6180X, can i use it for VL6180?Which example could i use just for 1 sensor read range?
2023-07-19 12:25 AM
You can find the API of the v6180 on st.com on the product page here in the "Tools&Software" section.
Here is the direct link to the API for the 6180 : STSW-IMG011.
Anne
2023-07-19 12:25 AM
Anne
