2024-10-29 12:18 AM
I've previously posted asking about gesture and hand posture output and I've finally got an output from both of the model. The problem is the method of getting an output for gesture and hand posture is different. For gesture, I'm able to use GestureEVK software and achieve some results for gesture but for hand posture I'm only able to get an result through local terminal/Putty. Is it possible to integrate both of the processses to have them running on one program that can recognize both gesture and posture?
Or is it possible that there are already methods of have gesture and hand posture running on one program?
Any ideas or hint would be useful! Thank you!
Emily
2024-11-06 5:58 AM
Motion gesture and Hand Posture are 2 different solutions. That's why it's not the same API to get the outputs.
Yes, it is possible to merge both solutions. It has been done internally in ST for some demos and it will come in the coming months on st.com. (Motion Gesture + Hand Posture + Smart Presence Detection)
This is something you can do on your side, and I can try to give you few hints:
App_Config.RangingData = RangingData;
/* Pre-process data */
Network_Preprocess(&App_Config);
/* Run inference */
Network_Inference(&App_Config);
/* Post-process data */
Network_Postprocess(&App_Config);
Then, you will have to merge both outputs, for example you can have this kind of code:
//Write the AI output in the Gesture structure for the GUI EVK
if (evk_label_table[(int)(App_Config.AI_Data.handposture_label)] != 0) {
gest_predictor.gesture.ready = 1;
gest_predictor.gesture.label = evk_label_table[(int)(App_Config.AI_Data.handposture_label)];
else{
gest_predictor.gesture.ready = 0;
gest_predictor.gesture.label = 0;
hold_timer = sensor_data.timestamp_ms;
That's just some hints, I hope it will help you.
Yann
2024-11-06 5:58 AM
/* Run inference */
else{
Yann
