2022-09-23 2:42 AM
Hello, I am working on vd6283 sensor to interface with NRF52 chip, I able to get data from the sensor, for ALS values and flickering extraction, but the problem I am facing is that I am unable to operate the sensor both for flickering frequency extraction and ALS values... at the same time.
And unfortunately, I am unable to find an example pseudo-code that tells us how to use the sensor for both operations at the same time.
Thanks.
2022-11-18 5:48 AM
Sorry for the delay in the answer.
If you are still looking for a pseudo code, you can find an example in this application note : https://www.st.com/resource/en/application_note/an5639-flicker-extraction-using-vd6283-stmicroelectronics.pdf
Anne
2022-11-18 5:48 AM
Anne
