2022-06-16 7:49 AM
2022-06-16 7:54 AM
There is a Range Status that you can read from the sensor. It will tell you what happened. But basically if you don't get a '0' status, something went wrong and you cannot use the result.
This 'Range Status' is not the result of your function. Your 'read_result' function worked just fine. This is a register returned by the sensor giving you the hardware status.
With no object, no photons will be returned, and your Range Status will return a 'no signal' status.
but there are other conditions you should look for.
(Generally the Range Result will be 8192 minus the status, but don't count on it. Check the Range Status.
2022-06-16 7:54 AM
