Increase bearing update rate on TESEO VIC3DA
RGOrdeig
Associate II
I am working with a TESEO VIC-3DA on a custom board, communicating with a microcontroller. I have configured the RMC message to be sent every 1 ms.
However, I noticed that the bearing field (listed as TrackGood in the software instructions datasheet) is not being updated at the same rate. Instead, this field only updates once every 1 second.
My questions are:
  • Is this the expected behavior for the TESEO VIC-3DA?
  • Is there any configuration option or method to increase the update rate of the TrackGood/bearing field to match the configured RMC output rate?
Thank you in advance for your support.
1 REPLY 1
GalaxyQuest
Hi Rodrigo,
Can you please provide a log of your observations? Meanwhile, let me check with our team internally and get back to you.
Thanks,
George
