2019-11-24 5:17 AM
Does TeseoIII have any programmable or any other indication to provide GNSS Jamming detection?
2019-11-25 12:14 AM
Hi Dror
You can have a look @ https://www.st.com/resource/en/product_presentation/presentation_teseo_3_security_mm.pdf
Hope this helps
Francesco
2019-11-27 6:54 AM
Hi Francesco,
The referenced document above is referring to GNSS modules with regards to GNSS Jamming detection (3-bit ADC converter, AGC and ANF).
What extra hardware does the GNSS module have internally which is different than using only the TESEOIII IC as a solution for Jamming detection?
2019-11-27 6:58 AM
Hi Dror
Sorry but the document is addressing both TeseoIII chip and Teseo Module because all the Anti-Jamming capability are inside to the chip or the firmware.... not related to special component on the module.
Hope this helps
Francesco
