ST Staff marking solutions
Andrew Neil
Super User
Sometimes (often :frowning_face: ), the OP disappears without marking a solution - even when it is obvious that a solution was found.
In this case, I sometimes see that ST Staff will mark the solution.
This seems fine to me, but I  think it would be good to distinguish when this has happened.
eg, here:
https://community.st.com/t5/stm32-mcus-products/what-is-the-smallest-achievable-delay-in-microseconds-for-a-16/m-p/684830#M251961
The notification tells me this was marked by ST (@mƎALLEm ) - not the OP:
But there's nothing to show that in the thread itself.
On the TI forums, they do separately identify, "TI marked this as the solution"
2 REPLIES 2
I understand why sometimes the OP disappears (for instance losing access to work email due to changing jobs and ST doesn't allow changing email address). Good idea to show who marked the solution. Transparency is important.
Kudo posts if you have the same problem and kudo replies if the solution works.
Click "Accept as Solution" if a reply solved your problem. If no solution was posted please answer with your own.
Lina_DABASINSKAITE
Community manager
Hello @Andrew Neil ,
Thanks for this idea! This matter is on our radar already, but I can not give you the exact timeline for the implementation yet.
Once we will have more news, I will let you know.
Greetings,
Lina
