2026-01-31 7:09 AM
Using Safari 26.2 I'm unable to delete or edit my own posts. Does anyone else
2026-01-31 7:51 AM - edited 2026-01-31 7:51 AM
You should be able to edit with the down arrow in the top right of your post or reply. No problems here doing this with Safari.
You cannot delete posts. You can flag them as “inappropriate content” and use the note to request a moderator delete them if you want. Usually editing is sufficient.
Edit: test.
2026-01-31 10:05 AM
Thanks, but that doesn't work for me. Odd. What happens after you select "Edit Message"?
2026-02-02 12:19 AM
Hi @David Littell,
Thie should work for you on all browsers the same. You have to be logged in for this action. Once you hit Edit message, you should see the text editor window:
Please see if you experience a different behavior on different browsers and let me know.
Regards,
Lina
2026-02-07 6:49 AM
Hi Lina,
I can edit posts using Firefox but not Safari.
2026-02-09 3:02 AM
Thank you. I have just tested version 26.2 with your account and edit l functions worked correctly.
Does this problem occur on both mobile and desktop? I will determine the next steps for troubleshooting your case after you answer the question above.
Thanks,
Lina
