2024-12-02 2:57 AM - edited 2024-12-02 3:03 AM
Example today:
I see similar about once a week ?
PS:
Interestingly, a search for """ seems to interpret that as quotation marks:
2024-12-03 3:43 AM
Hi @Andrew Neil ,
Thanks for sharing this! Seems that the respective member has simply inserted the title incorrectly over there. There is no issue with the title section. If you notice similar posts, simple report them using "Report Inappropriate Content" option and we will take it from there.
Regarding:
@Andrew Neil wrote:PS:
I will report this to check if this is expected behavior.
Let me know if you will notice anything else. Thanks!
2024-12-03 5:17 AM
@Lina_DABASINSKAITE wrote:Seems that the respective member has simply inserted the title incorrectly over there.
It seems highly unlikely that @JPabl.1 would manually type """ like that - twice - so looks like something the forum has misinterpreted?
2024-12-04 1:49 AM
Hello @JPabl.1,
Could you share the process of typing/copying text in your titles, so we can check if there’s something wrong with this feature?
I did the test with copying and typing simple quotes ("") in the title and saw no issue so far.
Thanks!
2025-01-06 2:47 AM - edited 2025-01-06 2:48 AM
Another one today:
@phamtutailtvm - can you describe how that happened?
(I've edited it now)
2025-01-06 6:03 PM
I need a header file named "TrajCtrl.h". I want to build an EtherCAT project on the STEVAL-ETH001V1 kit. But I can't find this file in the vendor's firmware.
2025-01-07 2:13 AM
@phamtutailtvm I'm asking here how you ended up with those raw HTML tags in your post title:
For discussion of the actual issue with your code, stick to the main thread.
2025-01-07 11:35 PM
I don't know. Maybe it's a typing error.
2025-01-08 1:09 AM
how did you create your title: copy & paste? manual typing? other?
2025-01-08 2:02 AM - edited 2025-01-08 2:07 AM
And another today:
@ronaksm - how did you enter the title of that post? Was it a copy & paste from somewhere? If so, where?
(This is just about the issue in the post title - keep discussions about the actual problem in the original thread)
