Forum migration lost code formatting
waclawek.jan
Super User
I've noticed that for example in https://stcommunity.st.com/t5/stm32-mcu-products/word-select-frequency-when-i2s-format-is-setting-to-pcm/m-p/478129 the inserted code is flowed instead of formatted as code.
ST, can this please be fixed?
@Legacy member
23 REPLIES 23
Absolutely correct suggestion and sorry not to have looked through the list of things carefully enough myself. You see, even among ST colleagues there is still a need to learn. :)
BTW: smileys/emojis also do not work yet.
/Peter
Peter BENSCH
Speaking of learning needs - it looks like you can no longer just reply to a message in a thread like you used to, so the reply is directly below the question/message/etc in question, but always at the bottom. On the one hand, you don't get confused by many side branches that often made you lose track in the old community, on the other hand, exactly what you just criticised happens.
Summary: it is indeed better to limit threads to exactly one topic and to create a new thread for deviating topics.
/Peter
Not applicable
Yes, generally, I wholeheartedly agree.
However, discussing the new forum appears to be a picky topic, your colleagues have already censored Clive's post from yesterday. So I did not want to inundate the forum with individual threads pointing out the flaws.There will be many.
You can also switch to "tree view" (called "threaded" for extra confusion) of the posts lists:
which is what was Salesforces' default and probably only view although I never liked that.
Unfortunately, Khoros botched that one, too, failing to indent the posts to indicate the tree, so I definitively don't recommend it.
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
