2021-05-20 4:52 AM
I wan't update X-CUBE-AI from 5.0.0 to 6.0.0 package in STM32CubeIDE 1.6.1 from local. So I've downloaded en.en.x-cube-ai-v6-0-0-windows.zip on my desktop. When I try to Load Froma Local the package "This file is either corrupted or not a recognized...."
Below the part of error log:
!SESSION 2021-05-20 10:31:46.058 -----------------------------------------------
eclipse.buildId=Version 1.6.1
java.version=11.0.9.1
java.vendor=AdoptOpenJDK
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 4 4 2021-05-20 10:31:56.491
!MESSAGE CubeMX plugin appears to be active, Log4j initialization might be too late.
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 1 1 2021-05-20 10:31:56.644
!MESSAGE Log4j initialized with config file C:\Users\andrea spiezia\STM32CubeIDE\workspace_1.6.1\.metadata\.log4j.xml
!ENTRY com.st.stm32cube.ide.mcu.ide 1 1 2021-05-20 10:32:09.376
!MESSAGE Started RMI Server, listening on port 41337
!ENTRY com.st.stm32cube.ide.mcu.ide 4 4 2021-05-20 10:32:10.080
!MESSAGE com.st.stm32cube.ide.mcu.ide/META-INF/version/build_ref file not found, build reference will not be reported into properties
!ENTRY org.eclipse.ui 4 0 2021-05-20 10:36:24.202
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.IllegalArgumentException: The selected element org.eclipse.e4.ui.compatibility.editor=org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl@2cde0397 (tags: [Editor, removeOnHide, com.st.stm32cube.common.mx.startCubeMx, active], contributorURI: null) (widget: ContributedPartRenderer$1 {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer@346690d6, toBeRendered: false, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor, object: CompatibilityPart [partId=org.eclipse.e4.ui.compatibility.editor, properties=[], tags=[Editor, removeOnHide, com.st.stm32cube.common.mx.startCubeMx, active], wrapped=class com.st.stm32cube.common.mx.editor.CubeMxEditor, legacyPart=class com.st.stm32cube.common.mx.editor.CubeMxEditor, beingDisposed=false, alreadyDisposed=false], context: PartImpl (org.eclipse.e4.ui.compatibility.editor) removeOnHide com.st.stm32cube.common.mx.startCubeMxContext, variables: [], label: prova_H7.ioc, iconURI: platform:/plugin/com.st.stm32cube.common.mx/icons/MicroXplorer.png, tooltip: null, dirty: false, closeable: true, description: null) must be visible in the UI presentation
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:184)
