2023-03-20 2:42 AM
WE build computer vision application using STM32H7B3. we want use TouchGFX together with xCube-AI but for some reason i can not enable it the CUBE IDE.
2023-03-20 3:25 AM
STM32CubeMX doesn't allow 2 "Application" components so the workaround is for example to first haev a project with AI and generate the code and then copy paste the generated code in your project with TouchGFX.
2023-03-20 3:33 AM
@fauvarque.daniel
Thank you for your answer. is this walkaround already have been tested?
why there is such limitation?
Any plans to find normal solution for it?
