2019-07-22 9:23 AM
I have noticed that the latest version of X-CUBE-AI (4.0.0) has support for Tensorflow Lite. Therefore I tried to analyze a SSD Mobilenet v1 network that I found on this blog post:
When analyzing the .tflite model, I have an error: "TOOL ERROR: Unkown layer type CUSTOM, stopping". I suspect that this comes from the post-processing operations that implement the non-maximum suppression.
Where can I see the list of supported TFLite operations? Also the list of supported Keras layers were removed from the Getting Started with X-CUBE-AI .pdf.
I couldn't find those lists elsewhere. I would really appreciate some help! Thank you and kind regards
2019-07-22 9:31 AM
A lot of technical documentation has been moved in the pack itself under the Documentation directory
You can access it through STM32CubeMX with the online help of STM32CubeMX.
Leave the cursor on the "Artificial Intelligence X-Cube-AI" mode checkbox, you should have a tooltip with a link on the documentation
You can also access it directly in your home STM32Cube/Repository/Packs/STMicroelectronics/X-CUBE-AI/4.0.0/Documentation/index.html
2019-07-22 9:31 AM
2019-07-23 1:04 AM
Thank you! Found it in my /root folder.
