2021-10-14 1:17 PM
After the watchdog does a reset and the watchdog is enabled after the reset the watchdog will not cause a reset. The watchdog is enabled and not getting serviced but a reset is not occurring. What has to be done to get the watchdog working again?
2021-11-18 8:23 AM
if you had a first RESET due to the watchdog, it means it was well programmed and the IP worked as expected.
Is the SWT programmed the same manner after the RESET ?
Which SPC5 MCU/board do you use ?
Did you try the corresponding SWT demo from SPC5Studio tool ? (eg "SPC582Bxx_RLA SWT Test Application for Discovery")
-Olivier
2021-11-18 8:34 AM
2021-11-19 5:49 AM
I saw your issue is managed by ST support by Shahrukh who has already reproduced.
I let you with him.
Best regards,
-Olivier
