2023-02-08 9:40 PM
Hello.
i use SPC5Studio tool
i started import samples from application library / Bootloader ...
the project complie is ok.
i modified Makefile.
i know this file automatically generated
but i must modify the compile option
"HEX = $(U_GHS_PATH)gsrec -hex386" to "HEX = $(U_GHS_PATH)gsrec -hex386 -crc32"
and then, this compile is ok.
but. If i generate it again, the additional option disappears (-crc32).
prevent the makefile from being regenerated,
I want to put an option in the place that creates the makefile.
thanks
2023-02-09 1:49 AM
supposing you are working on SPC58ECxx
just modify your file:
C:\SPC5Studio-6.0\eclipse\plugins\com.st.tools.spc5.components.platform.spc58ecxx_rla_1.18.0.20221220104647\component\root_wa\Makefile.ftl
It will generate your Makefile with your new parameter each time (on ALL your SPC58ECxx projects!!!)
Best regards.
2023-02-09 1:49 AM
Best regards.
