2015-06-09 5:29 AM
Dear All ,
SPC5Studio 3.5.0 is available.*** Highlights ***- New SPC5-RLA components set for P-line MCU (with sample applications). SPC5-RLA provides ''Register Level Access'' to the MCU, in order to create a register oriented application. Four modes are possible: * Registers setup * Registers setup & interrupts * Registers setup, interrupts & GPIO (with pinmap wizard) * Registers setup, interrupts, GPIO & LLD- Windows 8 support- Official eclipse.org Market place plugin- New organization of features to prepare eclipse Market place integration*** Notes ***- Make sure to read the SPC5Studio Users Guide and Components Writers Guide in the help section.http://www.st.com/web/en/catalog/tools/FM147/CL1794/SC1809/PF255702?s_searchtype=keyword
Enjoy SPC5Studio,The SPC5Studio Team.2015-06-10 2:00 AM
Hello Erwan,
What is the procedure to download the latest release? I tried Help->Check for Updates but it shows that 'no updates available'. Please provide the steps to upgrade it.Mike.2015-06-10 2:17 AM
The download section is in the bottom of the page.i recommend you to save your old applications before installing SPC5Studio 3.5and to reimport it in SPC5Studio 3.5 Best regards Erwan2015-06-10 2:40 AM
Appreciate Erwan for quick reply.
Couple of queries,1. Regarding the saving the old applications, is there any specific settings/configurations that need to be saved? Or is it a regular saving of project?2. Regarding importing the old project, again any special steps to be carried out or it is just as simple as in current version?3. Regarding the HighTec C license, will the old license file still work or is it required to acquire new license?Look forward for quick reply before proceeding to new installation. Thanks.Mike.2015-06-10 6:34 AM
How to Import and export projects in SPC5Studio.pdf'' contained in the zip file.
3- The license should work .. the license is located in the directory c:\SPC5Studio\licenses Please follow carrefully the README-FIRSTInstallation content
*README-FIRST.txt : This file
*SPC56 Toolchain_overview.pdf : Presentation of the SPC5Studio tool chain
*SPC5Studio v3.5.exe : Spc5studio installer
*SPC5Studio_installation_procedure.docx : Installation procedure of SPC5Studio
*FTDI_Installation_driver_on_SPC560X_Discovery_board.docx : Installation procedure of FTDI driver
and COM port for SPC560x Discovery board
*''How to Import and export projects in SPC5Studio.pdf'' : Procedure to export Old project before
removing old SPC5Studio installation (if any)
*Release Notes.txt : Release notes of latest SPC5Studio release.
How to install ?
- Open first the ''SPC56 Toolchain_overview.pdf'' document and download Universal debuger(UDE) if needed.
- If you are already using SPC5Studio, please save all your existing projects exporting all your all project following
- Follow ''SPC5Studio_installation_procedure.docx'' instructions.
- Follow FTDI installation procedure to enable JTAG debug and serial port.
- Once SPC5Studio properly installed import your existing projects previously saved.
SPC5Studio is based on LUNA Eclipse (Faster and more efficient.)
Best regards
Erwan
