Is Symmetric Multi-Processing (SMP) supported on Stellar SR6 P7 R52+ cores
swu.1
Associate II
There are several R52+ cores available in Stellar SR6 P7 line, e.g. SR6P7C8.
I have question about the Symmetric Multi-Processing (SMP) support on these R52+ cores. Is SMP available inside R52+ cluster or among R52+ clusters?
1 ACCEPTED SOLUTION
Accepted Solutions
FSPIL
SR6 information is provided under NDA.
For any question, please contact local ST support, and do not post information/questions in this public forum.
Thank you.
Best regards,
Francesco
4 REPLIES 4
Giuseppe DI-GIORE
SMP is a matter of Operating System.
SR6P7 devices provides support for SMP Real Time Operating Systems.
There is no MMU so Linux OS cannot be supported.
Regards,
Giuseppe
Thanks Giuseppe,
SMP require hardware coherent for both CPU/Core, actually I found the atomic operation issue at following page,
https://community.st.com/s/question/0D53W00001wIF3sSAG/does-cluster-local-ram-support-exclusive-access-with-shareable-attribute-as-well-as-noncacheable
Do you have any idea?
Thanks
Hello @swu.1 ,
Did you get it to use SMP?
Best regards.
FSPIL
Thank you.
Best regards,
Francesco
