2023-10-26 1:30 AM
Hello.
I would like to know about the error of TSB582 consumption current.
Please let me know if there is a figure between it's consumption current (or quiescent current) vs. supply voltage for the number of parts, and data on minimum and maximum consumption current.
Thanks.
2023-10-26 4:10 AM
You may see a curve for one sample on the datasheet : https://www.st.com/resource/en/datasheet/tsb582.pdf (fig. 2)
If you need to size your application with the maximum value you should consider the values reported in the electrical characteristics of the datasheet.
Regards,
Pierre
2023-10-26 4:10 AM
Regards,
Pierre
