Data sheet for chip marked EZFT V6294AI MRC021?
Cal_Harrington
Associate
Hello, and thanks in advance for your help.
I'm trying to debug (repair) an old circuit board on which we have a 14 pin surface mount chip with the labeling, ST EZFT V6294AI MRC021.   
Is this one of your chips? If so, is it possible to get a datasheet, or at least a pinout as a couple of the pads have lifted from my board and I'd like to know if those pins are critical to the functionality, ground, or maybe even NC.
(@Peter BENSCH I saw your reply in this thread about product markings and thought of asking you directly, here, too.)
Thanks very much and Happy New Year to you all.
1 ACCEPTED SOLUTION
Accepted Solutions
Peter BENSCH
Welcome @Cal_Harrington, to the community!
it is the R2R quad opamp TSV6294AIPT, the product information can be found here. Pin 8 is the output of the 3rd opamp.
Hope that helps?
Good luck!
/Peter
2 REPLIES 2
Peter BENSCH
Hope that helps?
Good luck!
/Peter
Thanks @Peter BENSCH , for the welcome and the answer. That's just the info I needed. Now I need to see if the mfgr of this circuit used the third opAmp.
I appreciate the help.
Hope you have a great new year,
Cal
