CS42L51-I2C
DYann.1
Senior II
I have a evaluation board ST32L552E-EVAL, and I would like to know how it works the I2C with this component (for example to initialize the component. Do you know where can I find examples of this board with I2C communication ?
I can download an example name 'Demo' but I can't see the file '.ioc' about the clock configuration and also the other parameters to understand with this component.
Thank you for your helps
1 REPLY 1
DYann.1
Senior II
After downloading 2 online examples SAI_AudioPlay and AUDIO_Standalone, I don't see communication by I2C in the '.ioc' configuration file. Probably in this example we don't use the I2C bus. How I can find an example to communicate with the I2C bus of the CS42L51 component. Thank you for your helps.
