Analog and audio
Forum board changes
256D is written on the top of componenet , SOIC8 package I coudlnt find any tecnical information on the internet. Would you please help me what kind of IC is 256D?
Hello; I have the electronic circut card including ST microelectronics IC component. 256D is written on the top of componenet , SOIC8 package I coudlnt find any tecnical information on the internet. According to electronic circuit it seems an OPAMP. ...
TGurl by Associate II
  • 1208 Views
I have the electronic circut card including ST microelectronics IC component. On the top of component, 256D is written. Could you please help me what kind of IC is 256D?
Hello; I have the electronic circut card including ST microelectronics IC component. On the top of component, 256D is written. SOIC8 package I couldnt find any tecnical information on the internet. According to electronic circuit, it seems an OPAMP n...
  • 895 Views
MC33078:what's the meaning about MZ,GZ,EZ markcode on the top of IC?if it means different places of production? We find that the MC33078 with different markcode influences the tone colour we listen.The MC33078 is used in our KTV PROCESSOR
JYU.11 by Associate
  • 971 Views
Simulation output voltage of LM26904A IC in LTSPICE
Hello, I have simulated the spice model of LM2904 in LTSPICE for the input voltages as shown in figure , as per the theoretical calculation output voltage will saturate to supply voltage VCC=12 V , but from simulation results output voltage getting...
KT M by Associate
  • 1090 Views
TDA7498e as a monoblock.
If i want to run TDA7498e as a monoblock, do i then need the capacitors on pin 32 / 33..?Both pins are tiet to ground in mono.
RJens.16 by Associate
  • 633 Views
Help recognize the correct model of TDA729
Hi, I have an active subwoofer with a burned chip on it. Unfortunately the model number is unreadable in the last number/s. The reading says TDA729* and under it CZ041936. Is there a way to get the correct model? I tried to contact the manufacturer o...
UPari by Associate
  • 694 Views
I am looking for STEVAL-STLKT01V1 sensor tile product but I need info regarding how this product friendly with the environment and easy to installation and also security details.
Basically we are thinking to use sensor tile as a voice recognition module and for that we need some info regarding module train process how it will easy for user to train any customize voice ?And this voice recognition module able to distinguish two...
SNaya by Associate
  • 726 Views
Guidelines to port codes of ST FP-AUD-SMARTMIC1
Hey guys,I am using a STM32 F411E DISCO board and downloaded ST FP AUD_SMARTMIC1 library to learn audio feedback suppression caused by a mic and a PA ampliflier nearby. In the library C files given in the projects folder of FP AUD_SMARTMIC1, they are...
HS.19 by Associate II
  • 2877 Views
