Analog and audio
Forum board changes
TDA7266M max input voltage
What is the max signal input voltage for the TDA7266M? We will be trying to merge a tube preamplifier with a 7266 power amp to make a small guitar amplifier. We can always shunt input signal voltage with a zener as the tube pre has a fairly large ou...
SMoor.2 by Associate
  • 1028 Views
how to configure sta510f output 4 independent channels, instead of 2 - Channel Bridge, thank you!
I now use sta311b+sta510f, how to configure sta510f output 4 independent channels, instead of 2 - Channel Bridge,Or how to make sta311b in each channel PWM output full  PWM not half PWM, I can only get half the signal, bridge is not a problem TKS!
0xfdr by Associate
  • 761 Views
I2S channel digital mems microphone sound level meter
Hello, I'm trying to measure the ambient noise level in decibels (dB) using the I2S channel for a project. I am novice at stm32 microprocessors. I just want to measure the noise level of the environment. Can you help me? Can you send me a sample proj...
mcizmeci by Associate II
  • 1013 Views
How to send ADC data from memory to USB at high speed?
Hello community,I have been using Nucleo F413ZH for some time. So far I have used ADC for lower speeds and needed nothing more to read the data than STMstudio. Recently I have a problem that I don't know how to approach. I also don't know how to find...
KWalc.1 by Associate
  • 1166 Views
Low pass filter on ongoing samples.
Hi all,My application requires to sample a sensor and send the samples out in real time, without saving the samples.I am required to run a low pass filter on the samples, but here is the problem cause if I want to do it on 20 samples for example then...
JKhal by Associate III
  • 3328 Views
How to pass 10 arrays simultaneously in a for loop?
Hello everyone,I am trying to get data from 10 ADC channels and want to display all the data simultaneously on the LCD. I successfully get the data from ADC channels but unable to display it simultaneously .Please give me suggestions over it and i am...
Mohan1 by Associate III
  • 2322 Views
