Analog and audio
Forum board changes
AM looking for datasheet of ST Chip
Hi all, Can somebody support in getting datasheet of "324 ST MZCS903" which is a 14 - pin chip.Am unable to get from internet .Thanks in advance.Rohitrohit.kadecha@battrixx.com
RKade.1 by Associate III
  • 1122 Views
Low power voltage reference with NPN transistor
Hi,I'm looking for advise concerning a low power voltage reference using NPN transistor as following :Q2 is used as diode (with negative TC)Q3 is used as zener diode (with positive TC)This circuit create a temperature-compensated +6V reference.So my ...
BKOSI.1 by Associate II
  • 1317 Views
how to read FDA801 DB Data?
i read the data sheet about FDA801 and try to read DB data , the data i read were all 0x00 ,But none of the speakers came through , i think there is something wrong in my process procedure . Here's how I tried it:May I ask if this process is correct?...
Ssong.1 by Associate
  • 1099 Views
